Hi Ahmed,PRINCE2  is a process-based method for effective project management.U can Study Prince2 and Itil For your Project,it will be helpful and u can solve ur  cost estimation and cost control problem easily.Thanks & RegardsSoniya
Hi AhmedYou could explore the interelationship of the four cost elements.Fixed - Volume - Time - Percent.One exercise I set in a seminar was to list all the elements needed to create a 10,000 m3 of concrete in an isolated site (no readymix) and allocate a cost element to each one.Then reduce it to a cost per m3.For instance just for the water you need:Either a borehole & pump plus tank or a set of bowsers and a tank. Each of which will have a ratio of Fixed Time and Volume costs.Best regardsMike Testro
