Opening XER file from P6.r8 in P6.r7
22 years 10 months
Mohamed,
You want to use a text-only editor that that does not format your text with invisible codes.  If you are not very careful, Microsoft Word can modify your text documents by adding unseen codes that will spoil the XER-modifying process.  Instead select the Windows Start Button / All Programs / Accessories / Notepad and edit a copy of your XER file using that.  Good luck!
19 years 11 months
Dear Roland,
Thankk you very much for your comments...
I will press a little further on your receiving-side solution which as you said its involves using Windows Notebook (or any other text-only editor that won’t corrupt the file)... what do you mean by Windows Notebook OR text-only editor and if you can explain to me how to use them...
Thank you very much for your help.
Mohamed
22 years 10 months
Mohamed,
 The simple answer to your problem is to instruct the P6 V8.2 users to save their backups in Version 7.0 format (the version box is just to the right of the “Create a XER Backup” option button.
 A receiving-side solution involves using Windows Notebook (or any other text-only editor that won’t corrupt the file) and editing the version number in the first line of the XER backup file.  Care should be taken to only replace the “8.2” with a “7.0” without changing anything else.  Then just save the file and try it again.  You may want to try this on a copy of the XER file to make sure that you do not lose your only backup file.  Good luck!
