Oracle Primavera - PM6 Member for 18 years 9 months Member for 18 years 9 months Submitted by muhammad anwar on Wed, 2010-03-03 08:19 Permalink RE: Sample Project Jatinder, Put the cd1 in and explore it instead of autrun. open install/database/configAsst it will open database wizard select create new primavera database and put key EC C01 in and hit next. Select Microsoft Sql server[if not oracle database] and check to include sample project data Hit next Select PMDB database and hit next Select Load application data only and check to load license key hit folder icon to direct to license file. and hit next on warning screen. Then enter username: privuser and Password: privuser [if you are on defaults] server Name: localhost\primavera database Name: pmdb$primavera hit next and select Yes, I want to overright my databse with dafault data and hit next. if every thing was put right then it should update the database with sample projects. But be aware it will overwrite the existing database. so you need to backup if you have some projects in the database to save. Regards Muhammad Member for 22 years 9 months Member for 22 years 10 months Submitted by Alexandre Faul… on Wed, 2010-03-03 04:37 Permalink RE: Sample Project Kumar, why dont you reinstall P6 with the sample projects? Alexandre Log in or register to post comments
18 years 9 monthsRE: Sample Project
Jatinder,
select
Select
Hit next
Select
Select
Then enter
hit next and select
hit next.
Muhammad
22 years 9 monthsRE: Sample Project
Kumar,
Alexandre
