I want to generate S-curve for the BoQ Cost only. For this i made one resource named BOQ non labor and assigned to the activity.
I put that activity cost in status tab of activity detail windows in non labor cost space.
Now when i executing the progress update then the budgeted cost, which i put in non labor cost space is changed and new cost came which is multiplied by 8 x duration e.g.
activity cost = 10,000
activity duration = 100d
after updation the activity budgeted cost became
8 x 100 = 800
How to overcome this problem and where should i have to enter the activitys BOQ cost?
Please...
22 years 5 months
Member for22 years6 months
Submitted by Amreshwar Shukla on Tue, 2010-01-26 00:43
Dear Artagnan, Thank you so much for sending the files to me.
I am able to connect the access file with the P6 data with SDK,but when I hit Update activities or update resources it gives the error " Action Failed, Error Number 2950, stop all macros" and when I close the dialog box it gives the another box with the message "Properties not found"
what could be the reason?
It looks like that access macro are unable to connect with the excel sheet.
Can any body help me on this issue?
Thanks in advacne.
17 years
Member for17 years
Submitted by Abhishek Chhangani on Sun, 2010-01-24 14:12
Hi arnold, i have been generating s curve by assigning weightages to all wbs & activities & allocating a dummy labor resource to all activities. Then with help of top down estimation getting planned units & s curve. Do u have any other correct method of generating s curve?? Pls send me at abhishekchhangani@yahoo.co.in
Thx
16 years 7 months
Member for16 years7 months
Submitted by Athar Hashmi on Sat, 2010-01-23 06:51
dats right Artagnan, i dont have SDK installed in my computer. for this i have to check my IT department.
But by the way, how can i generate S-curve for cash folw in p6. I want to generate Early / Late / Forecast S-curve in P6. Please help me in this regard. What is the default procedure for that.
This is because no Primavera 6 SDK is installed in your system. If you have the installation CD, run the setup.exe and then modify the installation by adding the SDK. Accept all the defaults. That should work.
16 years 7 months
Submitted by Athar Hashmi on Thu, 2010-01-21 01:11
I have been using MSP 2007 all along and creating the S curve using visual reports. Ever since the company switched to the p6 I have not been happy about my S curve. Your approach and integration sounds like perfect. Could you please send a copy to my mail address?
16 years 7 monthsAll, D Artagnan clearly
All,
D Artagnan clearly says in his original post that anyone wanting this file should email him. You shouldn't be posting here with your email addresses.
Thread locked.
17 years 1 monthDear Artagnan, Could you
Dear Artagnan,
Could you please send me your S curve tools in the following email:
joshibalaram@yahoo.co.nz.
Highly appreciate.
Balaram
14 years 4 monthsI have not received any copy
I have not received any copy from you. Could you please sent a copy to my ID sati_242@yahoo.com
17 years 1 monthDear ArtagnanPlease could I
Please could I get a copy too for S curve at dindima83@gmail.com . Thank you
15 years 3 monthsHi Methew didi you receive
Hi Methew
didi you receive this s curve generation file
if possibile can u mail me
thanks
Mayank
15 years 3 monthsHi can u mail the s curve
can u mail the s curve generation file on mayank@etappd.com or mayank.magnum@gmail.com
thanks
Mayank
thanks
Mayank
14 years 5 monthsDear Artagnan,Please send me
Dear Artagnan,
Please send me the copy on chetanpathania@hotmail.com
much appreciated.
14 years 4 monthsHye D Artagnan, Could you
16 years 7 monthsRE: S-CURVE generation
Hi Dears!
Any one please let me know where should I enter BoQ Cost to generate Cash Flow?
8 x 100 = 800
Please...
22 years 5 monthsRE: S-CURVE generation
Thanks in advacne.
17 yearsRE: S-CURVE generation
Thx
Thanx Arnold
Your white paper on curves really amazing. i learned so many things.
Thanx Artagnan, for your coopertions.
May Allah bless you here and here after!
17 years 1 monthRE: S-CURVE generation
i recommend to send your request to our dear friend, Arnold Puy, because he has made a whitepaper about this.
Thanx
Thanks Artagnan.
I got the file. But i need some troubleshooting from you.
While executing message appeared:
"ODBC - Connection to Primavera P6 SDK failed"
Then I follwed the same what you mentioned in your PDF file.
Linked Table Manager (Window)-
Select All-
OK-
Select Data Source (Window)-
Machine Data Source (Tab)-
(Here I didnt find Primaver P6 SDK only user database was there). Then I clicked New...
ODBC System DSN Warning Window appeared with a message:
You are logged on with non-administrative privileges. System DSNs could not be created or modified.-
Please suggest what to do!
sent you already... please post your feedbacks.
15 years 10 monthsCan somebody send me a copy
Can somebody send me a copy of this program. I find it hard in P6 to generate S-Curves compared to P3. ce_mit_ram@hotmail.com
Dear
Please send me S-curve program too.
athar.hashmi@yahoo.com
Dear
17 years 5 monthsRE: S-CURVE generation
Mr Artagnan,
Mail me at cm@arconksa.com/ aftab.cmohd@gmail.com.
Thanx in Advance
Aftab
15 years 10 monthsRE: S-CURVE generation
Can u please send a copy of S-Curve to me.
Thanks A lot
akhtarmkhan@hotmail.com
20 yearsRE: S-CURVE generation
dartagnan
Please send me a copy to my email jong_jamandra@yahoo.com
already sent you guys. however, i am expecting some feedback. Thanks.
17 years 9 monthsRE: S-CURVE generation
can you please send scurve generation to my email, akhtar@taisei.ae . thanks in advance
hi Artagnan
can u resend me a copy i didnt get it,
Please send it on sachincsangai@gmail.com
thanks
Sachin
23 years 7 monthsRE: S-CURVE generation
Can you please send me a copy (jojo68502@yahoo.com)
Thanks.
Ernesto
already sent. please post your feedback.
14 years 4 monthsHi Artagnan, Can you please
Hi Artagnan,
15 years 9 monthsRE: S-CURVE generation
I would like to try this S-CURVE generation program.
Can you please send me a copy?
kspark2001tw@yahoo.co.kr
Thanks in advance a lot.
18 years 2 monthsRE: S-CURVE generation
can you send me one at my e-mail add rgbart2@yahoo.com
thanks,
Can I have a copy of the programe ?
babumather@gmail.com
18 years 3 monthsRE: S-CURVE generation
I would like to try this program. Can you please send me a copy?
ciprian_ip@yahoo.com
sent to you guys...
22 years 11 monthsRE: S-CURVE generation
Me too please
hemanth.vineyard@gmail.com
Hi Artgnan
Even i would like to have that program. Please if you could mail me at sachinsangai@yahoo.co.in.
I don’t know if it is right to ask before i see this program what is the diff between this and PATTLNK_632006_536-xerFileParser&Builder.xls.
The problem is i have not worked with SDK and don’t have any idea about it.. :(
Sachin
sent to you guys...
Please post some feedbacks
17 years 6 monthsRE: S-CURVE generation
Hi friend,
Can you please sent me a copy? My email id is "anandavijayan@gmail.com"
Thanks & Regards,
VJ
Qatar
I am interested to have a copy of the S-Curve for the P6.
Please send it to cornelis.vanklaveren@sbmoffshore.com
Thanks and regards Cornelis
14 years 4 monthsHello D. Artagnan, Please
Hello D. Artagnan,
Please send me a copy of your program at utkucil@yahoo.com. I will try i t with our existing schedule in P6.
16 years 11 monthsRE: S-CURVE generation
Please send it to ebpgono@yahoo.com
16 yearsRE: S-CURVE generation
hai,
Please sent the S-curve program to jameel499@yahoo.co.in
Jameel
sent to you guys.
Could you send me some feedbacks please...I would really appreciate it.
Please send me file
akhtar@taisei.ae
already sent guys.
D. Artagnan,
Please send me the program at shukla456@gmail.com
Many thanks,
A.S.Shukla
20 years 1 monthRE: S-CURVE generation
hi dear friends, can u please send me a copy of it.
jamiroquai_29@yahoo.com
im also using windows 7
thanks.
Pagination
