To roll-up the numbers,assign a user defined field with data type = Number and just enter the numbers activity wise and they would roll-up to wbs level.
i hope i got your problem right???
18 years 9 months
Member for18 years10 months
Submitted by Nader K. Rad on Tue, 2008-01-15 01:59
I may do not have any comments on the genral case.
That project actually sounds tricky to me! The whole idea is to chase phisical progress (actuals) against the planned progress and run the EV financial calculation. EV is not for calculating physical progress, as it does not need calculation! If you ment chasing the progress and cost diagrammes based on physical progress I am sure you can use actual progress column to enter physical progress percentages as well ;)
Hope it add sometime up!
18 years 9 months
Submitted by Nader K. Rad on Mon, 2008-01-14 06:42
I’m not an everyday Primavera user. My question is not case-oriented… I prefer to know if it has the ability or not.
By the way… the case is that we have a project, which is dictated to have separated financial and physical progress report, so I’m not able to use EV tools to calculate the physical progress.
19 years
Member for19 years
Submitted by Sean Moghimi on Mon, 2008-01-14 02:17
Will you tell us more detail about the data you want to summerise or run some calculations upon? Primavera 5 and 6 should give you the majority of fields and data you will need to do EVA or track cost and time. What other things you want?
P6 gives you up to 8 columns for integer, text etc.
18 years 9 monthsRE: Roll-up or formula in grouping items
Sorry Amit, I didnt understand!
Would you explain me what to do?
thanks
18 years 8 monthsRE: Roll-up or formula in grouping items
Well, It’s truly tricky, but it’s not my decision. One of the most strait solutions I have, is to use formula or rollup in grouping items.
Thanks Shahab.
19 yearsRE: Roll-up or formula in grouping items
Nader,
Dear Shahab;
Nader Hi there,
Shahab.
