Make sure that when importing that in the import update project options that you select modify and under Data Type: Project under calendars that you select INSERT NEW my guess is that it is using the default calendar instead of the one assoicated with the project.
Recently I have got few PRX files to convert into P6. I can convert P3 to P6 by using old version of my Primavera Software but I am unable to see correct end date. is it due to calendar? I am not sure whether I am importing it correctly or not. I am following below steps-
Step01: Conversion of .PRX to EXE and extract all P3 files.
Step02: Import files using old primavera.
After Import we can note change in project finish date. Can Anyone plz help me. I will be very thankful for this.
DK
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Wed, 2014-09-24 18:19
if you are not running a 64 bit operating system you can change the file extension from .prx to .exe and the selfextractor shoudl come up. If you are running a 64 bit operating system the only way to get it to self extract is ot install a virtual windows
once you install that then you can extract the prx files to regualr p3 files then copy the files to your regular windows operating system and import the p3 project into p6
16 years 8 months
Member for16 years8 months
Submitted by Ariel Malibiran on Mon, 2012-11-19 17:52
One more question, if i will import now the file, do i have to choose the default configuration or i have to modify it make sure that all activities, resources, calendar, act. Ids, and etc are still the same? Because in modify they offer what do you want to update and what to keep on the existing file.
I think your using P6 ver. 7. Mine is P 6 ver 0 only, this software provided by the client. My software cant manage to import it. Is there any possibility to downgrade it?
Thanks so much sir for the help. Because this is my first time to import program from P3.
Joseph
17 years 4 months
Member for17 years4 months
Submitted by jeoffrey reyes on Thu, 2010-08-26 06:41
Yes its an infra project. I will take over the planning & scheduling works which was done in P3. Can I give you the first week update as well to make it easy for me to use anyone of them. The first one i give you is the project baseline level 3, its not detailed. Because Im having trouble in transferring datas from P3 and then check it again if some of the dates moves.
Thanks so much Jeff. I will send you 2 P3 file to convert it as an XER. I appreciate your response.
Joseph
17 years 4 months
Submitted by jeoffrey reyes on Thu, 2010-08-26 00:11
I opened and checked your file already and I saw whats inside of it. It is an infra project right? Anyway, I will try to convert it to P6 XER file so it will be easy for you to open.
Sorry for my late reply. When i try it again using your extracted file, i came up with an error after check box and prompt me to exit or do more actions. The error display as "An application has been intercepted. Please note the event code for reference AVAA4-2216-F." Can you help me how to make it done from your genius mind?
Joseph
17 years 4 months
Submitted by jeoffrey reyes on Mon, 2010-08-23 06:25
Double Click the file and a dialog box will open for extraction...or Do you have P3 installed? If you have, you can do it there. Tools=>Project utilities=>Restore. let me know. or send me the file i will extract it and i will send it to you all the files.
Sorry I cant find how to extract it since its already in a folder need not to be extracted just like what we have in zip files.
Can you make it clear where im gonna extract it, is it the prima to extract it or im gonna extract it to the folder which i think not possible since its already on a folder. Correct me if im wrong.
Joseph
17 years 4 months
Submitted by jeoffrey reyes on Mon, 2010-08-23 05:13
Its on a usual folder not inside a zip file. When i come up with the project directory browsing then it stops on the folder without getting inside the folder for PRX file.
Joseph
17 years 4 months
Submitted by jeoffrey reyes on Mon, 2010-08-23 04:39
I try it but i was stopped on browsing under project directory. And I cant even see a check box for my file to select. And P6 said that i didnt choose any project to import to proceed.
17 years 4 months
Submitted by jeoffrey reyes on Mon, 2010-08-23 04:13
In the File Menu....Select File=>Import=>Primavera Project Planner –(P3)…then click next...from the P3.3.x Project Directory browse for your file...Check the box when you see it....then follow succeeding instructions.
16 years 3 monthsyou do have to have the
you do have to have the project open to change it
5 years 11 monthsAre you referring to the
Are you referring to the Project Must Finish By date? You may have to have the project opened to change it.
Have you tried exporting the project form P6 as an XER and then re-importing it as an XER might fix this as well.
16 years 3 monthsMake sure that when importing
13 years 6 monthsHello Friends, Hope you are
Hello Friends,
Hope you are doing well.
DK
16 years 3 monthsif you are not running a 64
here is the link
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-…
16 years 8 monthsp6 cannot read the backup
p6 cannot read the backup file .prx of p3. you will be needing to restore it first to p3 files before you can import it to p6.
17 years 4 monthsRE: Cab somebody help me to import P3 PRX file to P6.0
Hi Joseph,
Better check if the default is fine with you.
15 years 2 monthsRE: Cab somebody help me to import P3 PRX file to P6.0
Hi Jeff,
Joseph
Hi Jeff,
Joseph
Hi Joseph,
Sent already. Please check your mail.
Hi Jeff,
I appreciate it. It would be a great help to finish my progress this period.
Happy Planning!!!
Joseph
Hi Joseph,
Ok, ill received it. ill convert it and send it to you one time.
Hi Jeff,
Joseph
Hi Joseph,
JEFF
Thanks Jeff,
Joseph
Hi Joseph,
Extracted and sent already.
JEFF
dyepreyes@yahoo.com
Hi Jeff,
I think its better to send you the file. Because i double click its trying to open P6 not the extraction box. Can you give your email plss..
A lot of thanks.
Joseph
Hi Jeff,
A lot of thanks.
Joseph
Hi Joseph,
Hi Jeff,
Joseph
Hi Joseph,
OK, extract it and you will find your file there.
JEFF
Hi Jeff,
No, I didnt extract it. I just copied the folder from the stick. It was a bit strange that P6 doesnt recognize the file under the folder.
Joseph, as i said on my last post if you extract your PRX file first?...because PRX file cannot be read.
Hi Jeff,
Joseph
Joseph, Did you Extract your PRX File? If not extract it and put it in another folder and browse from it.
Hi Joseph,
Did you click on the button with 3 dots? after clicking that it will show you ...Browse for Folder dialog Box.
Hi Jeff,
Hi Joseph,
JEFF
