If your version of Windows 7 is 64 bit then P3 will not run, you will have to set up a virtual machine and instal P3 on that, click on Start\Programs and scroll down to virtual machine and follow the instructions
15 years 3 months
Member for15 years3 months
Submitted by Mahmoud Amin on Wed, 2010-10-13 17:01
There are two versions of Windows 7; one is 32-bit and the other is 64-bit. P3 loads and runs fine on a 32-bit Windows 7 machine. To run P3 on a 64-bit Windows 7 computer is a much more difficult process. If you use the 32-bit Windows 7, you should not have any problems. Good luck!
15 years 2 monthstry
try this
http://www.microsoft.com/windows/virtual-pc/download.aspx
http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars
22 years 5 monthsStart/Programs/Windows
Start/Programs/Windows PC/Windows Virtual PC
17 years 8 monthscould not find virtual
could not find virtual machine in Start / programs.
can you give a bit more detail
17 years 8 monthsthe 64 bit came already
the 64 bit came already installed on the machine. when i had this problem, i wanted to install windows XP but they dont have the drivers for it.
Maybe, ill try through the virtual machine
22 years 5 monthsIf your version of Windows 7
15 years 3 monthsP3 Ver.2
Hi Sayed,
try installing P3 Ver.2 i think it's ok with win7
22 years 10 monthsLoading P3 on a 64-bit Windows 7 computer
Sajid,
