As is making a complete copy of the filters and layout You have set up.
I usually flagf on the compress and remove access list option. The first one to save space, while the second to be able to use the schedule from a network version of P3 to a single users without the need to check out it.
22 years 3 monthsRE: File Transfer
Normally should work.
16 years 9 monthsRE: File Transfer
But the filter function doesnt work after you have restored the project... Anyone has the solution to this??
But he has just to see the work done, or may be also to make some changes?
You can backup the project, Tool->Project Utilities->Backup.
He will be able to restore it,Tool->Project Utilities->Restore, and to view with P3 or Sure track.
If he need to change layotu, run report and graphs!
23 years 8 monthsRE: File Transfer
why not consider the web publish by web wizard?
22 years 4 monthsRE: File Transfer
yOU CAN ALSO USE METAFILE VIEWER
22 years 11 monthsRE: File Transfer
One of the best ways of sharing P3 info is using the Acrobat PDF writer (or one of the alternatives).
Alternatively you can simply copy & paste into Excel.
