Monthly Progress Report & S-Curve
17 years
Dear Mr.Rivera,
This would be quite helpful in creating the reports.
But what if we have added resourse on the bases of manhours for all activities,and now we have updated the schedule by keeping target at backhand.
How we calculate the weightages for each phase/Area by incaporating Manhours.
is there any format/template to workout.
Plz guide..thanks
16 years 9 months
i want to create monthly progess report & S-Curve for acutal & planned data with P3
i want to know how i must save my data like %comp
in every month ,i must use 1 file for 1 month or 1 coulmn for every month or other ways
& how i can use weighting factor for each tasks
& find total %comp with weighting factor for each level of project
24 years 6 months
First you need to have a target schedule and a working schedule that you are using in your project and updating regularly.
Second, you need to decide in one common way of measuring progress: manhours, cost or duration.
Regarding your weighting factor, there is no direct way in P3 for doing this. You need to work around it.
For example, if you are using manhours, you can setup another resource with a quantity equal to you manhours times your weighting factor.
Then when you format your report, you select this new resource for reporting.
You do not need to save each schedule update in a separate file. You can use your last updated file and report in whatever frequency you need (month or weeks for example).
The above are the basis for formating your report. If you need help in formating your report, please tell me.
