Loading resourse with global change
Ant Pir
User offline. Last seen 3 years 31 weeks ago. Offline
How to load resourse using global change in P6?
User offline. Last seen 2 weeks 3 days ago. Offline
BUSAYO ABIOYE
what does "I need a template for progress measurement for tracking engineering progress and also for tracking procurement progress"  and ?How to use global change to change activity ID please?
have to do with
Loading resourse with global change ?
please create a new post do not piggyback on a diferent subject
BUSAYO ABIOYE
User offline. Last seen 8 years 3 weeks ago. Offline
BUSAYO ABIOYE
option #1 as Raymund suggested is the global change will add the resource to all of the activities with the same code or wbs or any identifier
another option is at the activity level highlight the activitie that you want to add resource for and right click and select assign resources and select your resource.
yet another option is to assign a resource to one activity then export this information to excel and copy the resource information to the other actvities in the spreadsheet and import the activities back into P6 from excel. (make sure that calcuate costs from units is NOT checked)
User offline. Last seen 32 weeks 4 days ago. Offline
Antonio,
Oprion 1...
Subject Area =Activity Resource Assignment. If Activity = (Select Activity Codes or WBS or any Identity) Then Resource ID Name = (Select Resource)
Option 2...
Organize your Activity Layout to group the Activities with the same Resources together. Use add resources under the Activity Detail.
Option 3...
Use the Excel Import through the SDK...
