Resource Codes & Cost accounts
Haresh Jayanth
User offline. Last seen 7 years 19 weeks ago. Offline
Can anyone give me some references / links on internet for the topic "uses and advantages of using resource codes and cost accounts" in planning ......
thanks in advance..
User offline. Last seen 25 weeks 2 days ago. Offline
Haresh,
Resource Code is the same as Activity Code but more resources specific grouping like, company grouping, crews grouping, specialty grouping, skills grouping etc…
Cost Account is commonly used in Cost control management and EVM.
It is a management control point at which budgets (resource plans) and actual costs are accumulated and compared to EV for management control purposes. A cost account is a natural management point for planning and control since it represents the work assigned to one responsible organizational element on one program WBS element
Below are some links for your reference:
Cost Control, Monitoring and Accounting
Project Cost Control: The Way it Works
IS THE EARNED-VALUE METHOD AN ENEMY OF WORK FLOW?
Technical Managers Earned Value Management User’s Guide
User offline. Last seen 19 weeks 4 days ago. Offline
CPM Coding
Keep as many cost code groups as required, you might need a cost code set for your company Job Costing using same cost accounts across all your jobs while you migh need a particular cost coding set for every job BOQ as per the Owner requirements.
