Planning, Scheduling & Programming Discussion Member for 19 years 11 months Member for 19 years 11 months Submitted by Keith Lam on Fri, 2005-12-16 03:38 Permalink RE: Basement Construction methods Generally Speaking, Basement construction with watertable problems includes: 1) Diaghram Wall with high-strenght waterproofed concrete 2) Cavity Wall with sump-pit for drain out the water at basement (mostly recommended)and the construction should be carried out stage by stage Sequence (Diaghram Wall) 1) Setup dewatering instruments around the basement 2) Start excavation to required depth 3) Install Diaghram Wall Log in or register to post comments
19 years 11 monthsRE: Basement Construction methods
