P6 version issue? Edit, User Pref., Application - why do only some versions show "Codes" value vs description choice?
John Reeves
User offline. Last seen 10 weeks 20 hours ago. Offline
I am using version 18.8 P6 version issue? Edit, User Pref., Application - why do only some versions show "Codes" value vs description choice?  I have seen snapshots on Linkedin of the choice "Specify how to display code values" - I do not get the choice and do not see a format column for the Value Description.  I can only show the value, which of the two is the less preferred.  I tried exclusive mode, no difference.  Any ideas why or how to correct.  Yes I can make a UDF but I have seen the option - just do not have it.  Perhaps they made it a column choice that I just do not see.
Andrew Podolny
User offline. Last seen 2 years 6 days ago. Offline
John,
Check that you (your loign) have Admin Superuser privileges under Admin->Users.
User offline. Last seen 2 weeks 6 days ago. Offline
Rodel is correct
however even in version 8.2 you can also go to edit user preference and under Group and sort select show id / code instead of show name / decsription
User offline. Last seen 2 days 22 hours ago. Offline
This issue has been addressed in P6 version 20
Codes-Options
I guess you can create another code and make the description the same as the code value
i.e.
responsibility
code value    code description
civil              civil
I think that you can do it as a global change
