Work / Status date
17 years 9 months
Permalink
Dan,
MSP does not prevent you from entering progress into the future. And in this case, how do you want MSP to know when exacty the resource has worked?
There are many ways to spend 15 hours on your task. E.g.
Mon – 7 h, Tue – 8h
Mon - 5h, Tue – 10h
Mon – 6h, Tue – 6h, Wed – 2h
Mon – 3h, Tue – 3h, Wed – 3h, Thu – 3h, Fri – 3h,
MSP just takes the most logical assumption: resource worked in accordance to the plan (6h a day in your case). If resource worked differently from this – you have to enter this manually
15 years 8 months
Permalink
Sorry for the bad picture
/Dan
15 years 8 months
Permalink
Hello and thank you for fast replies,
I will add information for you so you can understand my problem.
The calendar is set on Monday to Friday, 8 hours/ day. 40h/week.
[[wysiwyg_imageupload:1565:]]
So the resource is working 75% out of 100%. Planned 6 hours/ days which means he is available 2 hours more, but still MSP places the hours in the future.
I can fix this problem by manually put in the data in the resource usage view, and that’s fine. But there has to be a way that MSP calculate this automatic.
17 years 9 months
Permalink
Dan,
MSP allows different ways to enter progress, and some of them may produce incorrect update (like in your case).
As Rabey suggested,  you can use the Task Usage view and enter hours into the actual work field.
Note, that in your case you actually spend more than you planned, therefore MSP may recalculate the remaining work and reduce it (I noticed, that different versions do it slightly different). Hence when entering progress you not only have to update spent efforts, but also update remaining work.
The picture below is from MSP 2007. But MSP 2010 should be pretty much the same. You noticed, that I assumed, that resource spent Monday 8 h and Tue 7 h, but in MSP you can enter actual time spent with the entervals as low as 15 minutes.
e.g.
Mon 04.03.13 08:00 - Mon 04.03.13 08:15 - resource worked 10 minutes on the task
Mon 04.03.13 08:15 - Mon 04.03.13 08:30 - resource worked 15 minutes on the task
Regards.
Evgeny
19 years 11 months
Permalink
You have not really provided enough information but if you show the times it should be enough.
It appears that you have a calendar with 6 working hours per day, and I assume that this calendar applies to both the task and the resource, but what is the start and finish time of the day?
Assuming that you have a day defined as 6 hours (Options), and if the task started at say 08:00 on 2013-03-04 then that day finishes at 14:00. Same for the second day. You can use the task usage view to input the 15 actual hours of work but you will have to know where the 15 hours occurred over the two days. Was it 7 + 8, or 8 + 7, or 6 + 9 or what and where were they?
