Just delete all of the resources for 2 of them (ctrl-D) from a blank cell) directly in the Resource Names column of the Entry Table. Then run/print the graph etc in Resource Graph View, then close the file, dont save, re-open and do the same for the other buildings.
Or save the Resource Names column in a spare text column so you can copy/paste to and from it so you dont have to close and re-open.
This might seem clumsy but should work.
17 years 4 months
Member for17 years4 months
Submitted by Andrew Owenson on Mon, 2008-07-07 06:42
Thanks for your quick response - tried it doesnt work! the filtering obviously does, but the resources are still for the whole project and I can only view them individually not as a whole or summary no. of men. Thanks for trying though
Andrew
19 years 11 months
Member for19 years11 months
Submitted by Trevor Rabey on Mon, 2008-07-07 06:36
Since you need it quick, here it is rough and not checked.
Easiest way to separate the buildings is to use a spare Text field and just fill in the field with ctrl-D (fill down) Building 1, Building 2 etc, then make a filter (Project, Filtered For etc) which reads the field.
I think that if you filter out the buildings you dont want and then go to the Resource sheet, Resource graph etc, you should get the graphs just for the building that the filter brings back. Not sure, not checked.
19 years 11 monthsRE: Resource Charts - filtering & Summary
Say you have 3 buildings.
17 years 4 monthsRE: Resource Charts - filtering & Summary
Trevor
Andrew
