weekly manhour distribution
Nar Thap
User offline. Last seen 17 years 26 weeks ago. Offline
I picked up the project from the middle which was a non resource loaded plan. Several weeks has passed now and I need to distribute the manhours on the activities. What is the most appropriate way to distribute the manhours so that weekly manpower histgram be generated? Nobody has info that the where the previous manpowers were consumed.
cheers
User offline. Last seen 47 weeks 3 days ago. Offline
Hi Karthik
Welcome to Planning Planet.
Some advice - It is not a good idea to respond to a long dead thread - if you need help or advice then start a new topic in the appropiate section.
Regarding your query the best source of cost and resource data is the project BoQ / Cost Plan - speak to the estimator / QS to get to what you want.
If you are working with P6 and your WBS is set up correctly then it should be automatic.
KARTHIK NEOSTRUCTO
User offline. Last seen 13 years 32 weeks ago. Offline
Dear sir,
Good morning everybody, i am new joining in planning planet, i am freshers also,
i expert your guidence and help , i develop myself, pls coud u explain
how to calculate the manhour for overall project, weekly, monthly,
how to calulcate the production rate also
i expert the valuable replay
j.karthik
nscl
Larry Rino
User offline. Last seen 2 years 25 weeks ago. Offline
Nar, If you have the weekly quantities related to the consumed manhours, try to derive the weekly manhours from your actual production rates. I expect these manhours came from various quantities of completed work.
I.e. Weekly manhours = Weekly production rates /
Weekly quantities
I hope these helps.
Bijaya Bajracharya
User offline. Last seen 9 years 27 weeks ago. Offline
If you are trying to generate mapower histogram for the past for which you don’t have records, I would ask why do you need that? It won’t be any productive exercise.
The best thing is make a plan for the remaining manhours and start recording the actuals in a regular basis. That way after another several weeks, you (or someone in your position) won’t be in the same position as you are now.
