Organisational Charts
J
Jihad Daniel 👤 Member for 21 years 2 months
Dear All,
I find all your suggestions fine but remember that it’s not only how good you produce Org.Chart but also how quick you can modify and revise it.
J. Daniel
C
Chris Oggham 👤 Member for 22 years 1 month
Hi Guys,
I’ve watched this thread develop with some interest, and I agree that Visio is a superb tool. The problem with my organisation is that not too many people have it installed. While you can save Visio diagrams in different formats it’s easy to forget to do this.
One way you can get round this is to produce your organisation charts using Microsoft Word. Although most people are familiar with Word as a word processing package, you can produce excellent organisation charts with it, using a custom paper size in page set up if the chart is a large one. The diagram is saved as a standard Word document, so anyone can read it.
Chris Oggham.
Daya Sugunasingha 👤 Member for 24 years 4 months
I agree that MS Visio is the best tool that I have used to prepare organization chart. It is intuative and quick to learn and use and presentation is good
Ray Ferguson 👤 Member for 23 years 2 months
Thanks Guys
We use Visio, I didnt realise that it is the best on the market, guess you guys just confirmed that!
The structure and layout would be great, including examples of job titles used on larger projects!
Ray
S
Sukumaran Subaramaniyan 👤 Member for 21 years 4 months
Hi Guys,
Everybody taking about their preferences in using Visio, Excel, Powerpoint, CAD, etc.
Ray which software do you using at the moment to draw the organisation chart? If you can specify then the discussion can be zoomed down on the utilisation and creation of organisation chart.
Regards.
Alex Wong 👤 Member for 23 years 5 months
Ray
Have you consider using Pictures as well in your org charts
I had lots of clients love that idea, because if you had such a big team it will be good if people faces are in the org chart. I still think Visio is your best bet
Alex
Thanks Jaco
Do you know any references where I could learn more about differing layers of management used in construction, and the current job titles people are given on a job this size? I think it is Important to get the correct terminology to illustrate a professional approach and strategy.
Our company have never done a job of this size before, and I dont think there has even been that many jobs of this size in our country before.
Ray
J
Jaco Stadler 👤 Member for 21 years 10 months
Well
Since the project is 200 M. You should fine that your project team is a big team (I would estimate 50 to 150) people.
Well as all have said their is verious method xls / word /powerpoint/Visio. And you will also find some other on the market. Of the above Visio is the best but would be underutilise if used only for organogram’s
Not sure what type of project you are doing but have a look at your CAD software. This I have found to be the best for big project. the Reason it is easy to do AO size organograms and because you can filter layers. If you set it up correctly you can print resource list (equipment list) This is easy espacialy if you already have a draftie in your employment
As to how you will structure it is all depended on your existing organisation and also your implementation strategy.
Cheers.
S
Shahzad Munawar 👤 Member for 23 years
MS Visio is the best to prepare organization chart with respect to presentation and usage of tools
S
Ray,
Normally, I use MS Excel to draw the organisation chart. Go to Drawing toolbar. It has flow charts, connectors, lines and etc. Easy to work and faster. Once you have completed you can copy to MS Power Point for presentation.
Regards.
MS Visio is my favour, since its reasonable priced and easy to use
Alex
Featured Partner
xerxes
edwin
jhalluk69
wilmoahyi
Peter Holroyd
Robert Guers
Jerry Robinson
Elyar Safarov
Our Partners
