WBS Order not the same in Activity View
J
Josh Hardin 👤 Member for 13 years 2 months
When I shuffle my WBS hierarchy in the WBS view, it doesn't display the same in my activity view... Any ideas???
F
Fahad Shuja 👤 Member for 7 years
Hi Josh!
Hope you have found solution of the issue, please share it. I am facing the same issue.
M
Michael Akinleye 👤 Member for 9 years 3 months
Hello Everyone, Please my schedule Start and finish milestones are not showing in my activities ...please how can i fix it
H
Håkon Haukebøe 👤 Member for 13 years 10 months
Check View -> Group and sort by:
Uncheck "Sort bands alphabetically" if checked. This might help.
Haakon
Russell Manuba 👤 Member for 13 years 2 months
Hi Josh
Check your columns then click on the column head. You'll see an arrow down/up indicating that that particular column is being sorted. Usually the colomns on the WBS node is according to number incremental.
Hope this helps
J
I should probably clarify. It's my projects that won't show up in the same order when I shuffle them in the WBS view. I'm assuming the best way is to use a numbering system in the Project ID to get them in the correct order.
I tried to F5 with no success. Thanks for the reply Rizwan
rizwan khan 👤 Member for 13 years 10 months
Did u refresh the data  its under file option. please let me know if its work or not
Featured Partner
Tijo Kurian
Zainab El-Beialy
Kamlesh Parmessur
MR JUDE C ANYAEGBU
GeoVe
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
