What dose "As-Built" mean?
J
Jenny Ingco 👤 Member for 14 years 6 months
Dear All Planners,
What dose "As-Built" in engineering terms mean? and what is the diffrent between "As-Built" and "as recorded" which one is best to use?
Thak you,
Hanson
J
Hi Mike,
That was very helpfull. Thanks a lot.
Hanson
Arun Kumar 👤 Member for 14 years 3 months
As I know
"As built" is the term used for Construction Engineering drawings.
If we use any higher section instead of actual designed section shown in drawing then we have to show that actual section in drawing and submitt it to client.
Example:
If we have to use Plate 25 mm in Structural steel works, but we used Plate 28 due to shortage of Plate 25. Then we indicate Plate 28 mm in drawings because it is as built in construction. That means it is "As built" drawing.
Hope u understand.
Arun Kumar
Abubaker Ali 👤 Member for 15 years 5 months
As built drawings are the drawings as they are specifically constructed which may vary from the original design for a number of reasons
M
Hi Hanson
Generally As Built means the date and time that an activity was carried out.
As Recorded would be the same as As Built but not commonly used.
As Planned is the date and time when it was intended to be carried out accoriding to the current programme.
Featured Partner
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
edwin
jhalluk69
wilmoahyi
Peter Holroyd
Our Partners
