When copying WBS element the Activities are not copying?
David Ball
User offline. Last seen 13 years 6 weeks ago. Offline
Hi Forum,
I have opened up two projects together in P6 and have been copying WBS elements in the WBS window from one project and pasting them into the other. This pasted WBS levels and activities into the second project.
All the sudden when I copy a WBS element the activities are no longer being copied and I don't know why? I just get the WBS levels in the second project but not the activities.
Does anyone know why this would be happening?
Thanks very much
DFB
Arend Woltjer
User offline. Last seen 9 years 48 weeks ago. Offline
Hi David,
In my testing the only situation in wich the activities are greyed out is when the wbs element has no activities attached.
Maybe in the activity view / WBS grouping the 'hide if empty' option has played a trick with you?
Sorry I can not give  a better answer.
Arend
David Ball
Thank you very much Shahul. I will keep that in mind for future reference.
DFB
Shah. HB
User offline. Last seen 1 year 44 weeks ago. Offline
David Ball
It happens if two project have same Activity ID's,try by renaming Activity ID's in Project 1 and copy it to project 2
Shahul
David Ball
Thanks Kaif,
I don't get the choice to select "Activities" in the "Copy WBS Options" dialogue box as it is greyed out.
DFB
Kaif Mohsin
User offline. Last seen 8 years 9 weeks ago. Offline
Groups: GPC Qatar
Dear David,
While copying the WBS from one project to the other it has to be ensured that the "Activities" option is ticked mark in the "Copy WBS Options" Dialogue Box in order to copy the underlying activities also.
Hope this will sort out your problem.
