Data that can not be modified by Excel?
Utku Çil
User offline. Last seen 11 years 2 weeks ago. Offline
Here comes another question Planners,
What specific data can not be modified by exporting to and importing back from Excel? For example, I could not change the Activity Type of a task using Excel. Is it because it can not be done or am I just doing sth wrong?
Thanks in advance.
Amit Parmar (PMP)
User offline. Last seen 13 years 5 weeks ago. Offline
You can use Primavera SDK "Activity sheet" to edit the Activity Type for your activities. If you need help using SDK then mssg me.
Amit
Check out my blog on Primavera at http://www.primaverablog.in
David Kelly
User offline. Last seen 3 years 12 weeks ago. Offline
You cannot change activity type.
For a list of all the fields you can/cannot chnage - export all the fields.  Where there is a * in fron of the fields name
e.g. (*)Activity Type
The field cannot be imported and hence changed.
