How to feed directly the quantities of a Resources in the spreadsheet of Primavera P-6
Dear Friends,
I need S-Curves of a Resource (like Concrete) in terms of (a) Quantities and (b) Cost in Primavera P-6.  To do this I follow the following Steps
Step 1: I go to Enterprise > Resources > add a new Resource > here in new resource wizard assign resource ID, Resource Name, and then Finish. Now In Resource detail tab tick on material, drop down unit of measure and I assign meter cube for Concrete. Now in Unit & Prices tab I assign Max Units/ time (for Concrete I assign 1000 meter cube per day) and I also price/ unit from the BOQ price.
Step 2: Now if I need to assign this resource (concrete) then I select the activity and in activity detail tab > Resources > add resource and here I put Budgeted Units from the BOQ.
Step 3: and then to Resources usage Profile.
Now my Problem is this I have too many activities, and hence it is too much time consuming to select each activity individually and then to go to step 2. So is there any way like to feed directly the quantities in the spreadsheet of Primavera. The Quantity Surveyor gives me the quantities of activities in tabular format and if I can directly put in spreadsheet without selecting each activity and to follow Step 2, then I can save my considerable time.
I will appreciate your help and Time.
Best Regards
Faisal Hashmi
Z
Zoltan Palffy 👤 Member for 17 years
you do not need sdk to do this
follow your steps 1 & 2
assign the resource to one activity with the budget untis in it
you will use this as your template in excel to import the budgeted units back into p6
now export to excel
export the activities as well as the resource and resource assignments
when exporting modify the items in the export and make sure to export the
activity id, resource id and budgeted units
when you export the file to excel there will be 2 tabs
one tab is the activity information and the other tab is the resource informaiton
the tab labeled as TASK is the activity information and the one labled as TASKRSRC is the resource tab
go to the TASK tab and copy the activity id to the TASKRSRC you should be pasting into row 4 of the TASKRSRC tab
now copy the resource name down from row 2 to the other rows
now you can populate the budgted units just like you wanted to do
save the file and import just the resource assignments back into p6 you wil be prompted for what you want to import
the key here is exporting a template so that you can populate it quickly
Amit Parmar (PMP) 👤 Member for 15 years 8 months
Hi Syed,
I have emailed the files to you. You can use your primavera login id and password to connect to the database, provided the user has SDK access.
1) Dictionary6x - is used to edit Global data eg. Adding resources, calendars etc to database.
2) Activity6x - is used to edit Project data eg. Assigning resources to activities, editing units etc.
Please use the following worflow for inputting data.
Use respective "Get" button to retrieve data from database>> Edit the data (use "?" button on top for help) >> Once data has been entered >> Use "Set" button to send the data back into the database
Important Note - Once you have used the "Set" button to send data into the database and after that you decide to enter/edit more data, Use "Get" command again to refresh the new data from database otherwise there will be duplication of data. Always "Get" Data again after using the "Set" command.
Try using the sheets on a dummy project till you are not confident enough to work on a live project.
Amit
Hi Syed,
Glad to know you were able to configure SDK. When you login to Primavera using PMSDK, u will get the same data as PMDB. The schema for PMSDK is different cause SDK contains calculated fileds like "Total Float" which are not present in default database PMDB. They are calculated by everytime you press F9.
You need to use the following excel sheets to connect to your database and do the editing. The sheets are more or less self explanatory, you can use the "?" symbol on the top for help.
Note- Since you will be editing data at the database level directly, i would advise that you make a backup before using these sheets.
Please send me you email address, so that i can forward you the files.
Amit
U
usman arshad 👤 Member for 15 years 7 months
Faisal..
if u have same resources and different quantities, add up quantities for same, make new activity, change type to LEVEL OF EFFORT for that activity. link that activity SS with first activity & FF with last activity for a specific WBS. add resources in that activity. go to resources assignment. copy and paste to excel.
Usman
U
Faisal..
Usman
S
Syed Faisal Hashmi 👤 Member for 16 years 7 months
Thanks Anbin & Amit
I think I have successfully configured the PMSDK database.
When I  login to Primavera using PMSDK database the screen is same
as that of PMDB database. ( Is it configured correctly??)
Yes Amit what next I have to do to feed the quantity using spreadsheet of Primavera.
Faisal Hashmi
Anbin Ponnith 👤 Member for 17 years 1 month
Hai Sayed
For configuring SDK Type the Database Name as pmdb$primavera not(pmsdk$primavera)
Anbin
The default password for username:"pubuser" is "pubuser" without quotes. It should work with that.
Amit
S
Dear Amit
when i try to modify my program. The following error message i got
Bad public user name or password. Database Server Error: Login failed for user 'pubuser'.
Cannot open database "pmsdk$primavera" requested by the login. The login failed.;
Can you please  help me in configuring pmsdk.. i followed the same steps as been stated by you. i.e.
I Choose option "modify" when installing Primavera and then i  choose SDK as an option to install.
Faisal Hashmi
You can use CD1 in your Primavera Set for installing SDK. Choose option "modify" when installing Primavera and then you can choose SDK as an option to install.
Amit
You can install SDK and use the excel sheets given by Primavera to input the data in the database. Once y ou are done installing SDK you can update the post and i will email the files to you :)
Amit
Featured Partner
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
Akram Hammam Mohamed
Sagar Raut
