P6 locks up or is very slow when loading schedule
L
Leo Nicholson 👤 Member for 20 years 4 months
An old thread, but I use p6.1 and am  plagued with slow loading.  I am running on Windows 7 Pro 32 bit.  The program runs correctly, but takes a long, long time to load up.  The link to the instructions about this in the thread no longer works.
Also, is there any source for 6.1 service packs?  I can find reference to download links, but they are all dead also.
Any help would be sincerely appreciated.
Aftab C Mohd 👤 Member for 18 years 2 months
Hi all,
The problem I had with slow rate of loading up projects was resolved with "Fullcan" and gather stats as suggested by Keyel.
Brought down the loading time considerably low.
Thanks guys
Aftab.
S
Simon Toner 👤 Member for 21 years
I realize that this is years after this string was started; but I have used the fix suggested by Keyel and it has solved my problem.  My loading time has gone down from 15-20 mins to about 5-10 seconds.
K
Keyel Isorena 👤 Member for 19 years 8 months
Chris, Have you tried this http://primaveratools.com/Portals/PrimaveraTools/activeforums_Attach/001_slow_performance_P6.pdf? I cant try it since it needs an "SA" account and I have to ask our IT to do it for me. If you can try this and it helps, please provide feedback so we can suggest that this is a solution. BTW, in the forum where I found it, it says that it has to be redone every time the system slows down on loading again.
Keyel
K
Rodel, I am having the same problem as with Chris. I have checked the Primavera background agent and verified that it is running and that it starts automatically. Question is, is there a way to verify that the Symon and Damon are actually running, or better yet can we make it run everyday instead of weekly?
Keyel
K
Chis, I think I have the same problem as you have. We are running on a stand alone version of P6 6.1 on a 2.66 Ghz intel quad core with 4 GB of RAM running windows 7 32 bit. Our project having 9000+ activities loads but it takes about 20 minutes to load. Have you found a solution yet?
Keyel
Chris,
Yes it can, refer to your Primavera Admin Guide. I believed Damon run every Saturday by default.
C
Chris McMillan 👤 Member for 16 years
Is there a way to manually run the system monitor and data monitor? My background agent is running but I think my memory is full.
Chris,
It might be and your memory is not enough. It will not compact immediately. Cleaning will be done weekly so I’m not sure when the last run was. Observe for one week if still the same otherwise consult your IT to change the settings to daily and once it run smoothly change it back to weekly.
Note: Background agent is running I think because you said you just reinstall SQL again which just update the driver and run which means does not clean up the system.
Chris, another suggestion is creates another database and run using another database. You might find that new database is running fine. You can access any of these databases anytime.
C
Rodel,
Thank you for your response. My Background agent is running. However, I restarted it and the problem remains. Could my database just be too big?
Chris,
Check if Primavera Background Agent is running. (Select Start-> Settings-> Control Panel-> Administrative Tools-> Services. Look for Primavera Background Agent and double click. Click start if the status is not started. Also set Start up Type to Automatic.) The use of this service is to run SYMON (System Monitor)run daily and DAMON run weekly(Data Monitor). These two programs running in the background to clean up system and data (i.e. log files, caches, deleted files and recorded action for undo’s) If Background Agent is not running then PC will slow down and memory will be full.
Hope this help.
Featured Partner
jeoffrey reyes
markg
Manjeet Yadav
Pan
Tijo Kurian
Zainab El-Beialy
Kamlesh Parmessur
MR JUDE C ANYAEGBU
GeoVe
Ashkan Mohammadi
