Start and Finish FLOAT
Ali Farhat 👤 Member for 17 years 8 months
V
Vladimir Liberzon 👤 Member for 25 years 5 months
Start Float shows the delay of sctivity start that does not delay project finish if everything will be done as expected.
Finish float shows the delay of activity finish that does not delay project finish if everything will be done as expected.
Actually it is more interesting to understand the delay of activity finish that will not delay project finish if current activity will be done slower than expected (we call it super float).
I think that start float is most useful because you decide when to start each activity. When start is known finish is defined.
So what is the use of the option in Scheduling dialog box that allows you to choose betwee start float, finish float, or the smallest between them?
Ali,
One is calculated by Forward Pass and the other is calculated using Backward Pass.
S
Shah. HB 👤 Member for 17 years 7 months
Hi Ali
Both yields same result but the way of computing is different
Featured Partner
yerukalapudi
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
edwin
jhalluk69
wilmoahyi
Our Partners
