P6, how to create a copy from 20 projects on CD?
7 replies [Last post]
Abeer Mahmoud
User offline. Last seen 9 years 17 weeks ago. Offline
P6, I need to create a copy from 20 projects on CD/Directory by a simple way and one step.
Kindly note that your help is urgent.
Abeer
safinaz ALI
User offline. Last seen 11 years 49 weeks ago. Offline
Groups: TILOS
Dear Abeer,
Select the 20 project, open all (at the same time), then choose "Export" from "File" menue.
the 20 projects will have small size of MB that will be applicable to be burned on CD.
Safinaz
safinaz ALI
Groups: TILOS
Dear Abeer,
Open all the 10 or 20 projects in Primavera, then go to file export. Follow the wizard. This will create only one file.
when you will use this file you can import any wanted project seprerately from the exported file by shoosing "ignor this project" from the importing wizard this is good way instead of having alot of files.
Regrds,
Safinaz
Arnold Puy
User offline. Last seen 10 years 37 weeks ago. Offline
Hi Abeer,
If you are going to import it back to P6, the 20 projects that you have copied will also equivalent to that numbers.
However, if you want to copy it separately then I think you have to copy it one by one.
Arnold
Mohammed Abdul Mazid
User offline. Last seen 16 years 19 weeks ago. Offline
hi,
Before i start working on P6 I want to see the details of P6 will you please provide us the details
thanks and Best regards
Mazid
hi
I want P6 Detail version material
Abeer Mahmoud
Thanks Arnold for your fast reply,
but kindly note that I need the 20 projects separeat not one project.
Abeer
Arnold Puy
Hi Abeer,
Note: If your project is too big then you need to open 5 or 10 projects at the same time.
Arnold
