Event Code 2DVWV-3590-8
A D 👤 Member for 19 years 2 months
C
CLAVELAND ITUCAS 👤 Member for 10 years 5 months
DeaR aLL,
This mesage showing everytime when print preview and page set up. event code JPEGE-2077-2
Do you have any solution on this. Appreciated help
Such a silly thing....
Thanks Arnold for d help.
Arnold Puy 👤 Member for 19 years 2 months
Hi Raviraj,
You can change your calendar for the existing Activities using GLOBAL CHANGE.
Calendar = "Select Assign Calendar"
If you Wanted to change the selected activities only then you need to filter prior to run Global change.
Arnold
NO REPLY!!!!!!
Actually, I want to change the calender for the project.
Now, if i go to Enterprise --> Project --> Defaults, then we can chnage the calender there, but it will be effective only for all new activities to be inserted.
How, can I change the calender for the existing activities. (Say, there are 450+ activities).
If I change it from Enterprise - Calender, then it gives the below mentyioned code.
Is there any way out??
richu rose 👤 Member for 19 years 5 months
I too get the following message while changing layout
"An application event has been intercepted. Please note the event code for refrence.
Event Code AVAAO-0596-E"
After that P6 closes.
I contacted Primavera, but not heard anything from them.
Cheers.
Richu
Featured Partner
GeoVe
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
edwin
