P3e Database on a Server and a Local Copy
Al MacLeod 👤 Member for 19 years 5 months
K
Karim Mounir 👤 Member for 20 years 3 months
Al MacLeod,
You can install P5 locally into your laptop without the need of installing Oracle.
As Matt said u can run P5 using the MSQL server (which will be installed automatically), after that u can import/export or backup the database easily by going to: Start-->All Programs-->Microsoft SQL Server--> Enterprise Manager, then select your database and click on Import/Export or Backup/Restore.
Or u can simply export the schedules from the P5 itself using file--> export.
HTH.
Karim
K
Al MacLeod,
HTH.
Karim
K
Al MacLeod,
HTH.
Karim
K
Al MacLeod,
HTH.
Karim
M
Matt Rudge 👤 Member for 19 years 4 months
Hi All,
I run P5 locally as well as through server.
The local copy runs through a MSSQL server which is set up on my hard drive. I would give you more details but unfortunately our IT department locks us out from finding useful system info!
Hope this helps though.
K
Al MacLeod,
HTH.
Karim
Featured Partner
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
edwin
jhalluk69
