P5.0 Layouts & Filter
S
S LEE 👤 Member for 20 years 9 months
K
Kevin Button 👤 Member for 23 years
I guess you have to draw the line somewhere. If you include activity layouts, why not filters, resource assignment layouts, global changes, reports and tracking views? If you put in too many options, users will then complain about the level of complexity.
KB
Dayanidhi Dhandapany 👤 Member for 23 years 4 months
during import/export, an option should have been given in P5.0 to select the layout to be incorporated with XER file.
K
It is correct that XER files do not (ahd should not) contain layouts. I would not like to import an XER file, only to find that I have also imported several dozen layouts from somebody elses database that I don’t want or need.
It is much easier to import a single layout file than to delete many unwanted layouts.
KB
your suggestion will work for sure but we have to send these two files XER and PLF together as you said.
M
MK TSE 👤 Member for 24 years 4 months
Try this method. View - Layout - Open, you can find the Import/Export button. Send the XER with PLF
i too have the same problem. I could not find any saved layouts in the exported file of XER format when i tried to import the same in another machine. its really strange to me. if someone can give a suggestion on how to retain the saved layouts during export? would be appreciated much.
M
I don’t think it is possible. P5.0 is working on database. The saved layour can be shared by others. So it is not stored by the project.
Featured Partner
mxsiegel
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
