V5 : Copying Actvities of one project to other
14 replies [Last post]
Amar Aghana
User offline. Last seen 17 years 48 weeks ago. Offline
How to copy activities of one project to other project?
( I have Activities A01, A02 in Project P001. I want to copy A01 and A02 to Project P002. I tried opening both project and tried to paste. Could not succeed)
Henk van der Heide
User offline. Last seen 7 years 30 weeks ago. Offline
Open both projects, the one you want to copy from and the one you want to paste to.
Organize bij WBS, select the activities, copy, and past within the WBS of the new project.
You can also paste in the same project, now you have the activities double, and change the WBS of the copied activities
Because P3e is full multiproject you’ve to difine the wbs for each activity. When you dont use WBS it puts all activities in the same project (what’s a part of the WBS)
regards,
Henk
Wilmore Makonese
User offline. Last seen 19 years 26 weeks ago. Offline
I would suggest exporting the project( or activities ) you want and then importing it/them in the project you want it/them to be.
Marcio Sampaio
User offline. Last seen 12 years 45 weeks ago. Offline
Dear all;
This forum is for P3e users. We have another forum for P3 users.
Using this one to discuss about P3 cause confusion.
Best regards.
Marcio Eduardo.
Mario Sanvitale
User offline. Last seen 13 years 23 weeks ago. Offline
As Alex posted, there are no Fragnets in Primavera V5.
Surely copy and paste is the easiest option? Primavera V5 gives you options when you do that.
Marcio Sampaio
What!!??
Alex Wong
User offline. Last seen 12 years 16 weeks ago. Offline
Groups: TILOS
MUHAMMAD
It is P3e not P3 therefore there is no such thing as fragnet.
Alex
MUHAMMAD IQBAL
User offline. Last seen 7 years 39 weeks ago. Offline
hi
guys
why not u using "fragnent"
Amar Aghana
Alex, Thank you.
Thanks to all for participation.
Cheers, Amar.
Alex Wong
Groups: TILOS
Thats right becasue the software need to know which Node (EPS) you want to paste the activity that why you either group by "EPS/WBS" or Just "WBS"
Alex
Amar Aghana
Alex,
I have projects structured by activity codes not by WBS. When I open two projects and try to paste, it could not be done.
However, by default, WBS Level 1 is project itself. I grouped two projects by WBS for Level 1 and then tried. It worked out!
Alex Wong
Groups: TILOS
Amar
If you copy the activities in one project first, open both and organise it by EPS/WBS. Then you can select them and drop it into the project you wand to paste. Make sure you have rights to both projects.
HTH
Alex
Shah Shams Alam
User offline. Last seen 13 years 34 weeks ago. Offline
Select both the projects in Entrprise breakdown structure using controll key. Right click and open, Both the projects will open. Now u can copy and paste.
Marcio Sampaio
Open both projects. Than copy and paste.
Harold Martin
User offline. Last seen 13 years 15 weeks ago. Offline
Muhammad,
Highlight the activities you want to copy go to tools fragnet, store fragnet put ID & title, then open other project go to fragnet, retrieve fragnet than select.
kind regards,
Harold
infrastructure/tower projs.
