P3e Baselines
Alan Chadwick
User offline. Last seen 11 years 35 weeks ago. Offline
Whilst accepting that P3e is an entirely different product to P3, how have other users found the baseline functionality - or rather limitations of it compared to P3.
i.e. if new tasks are added, the update of existing baselines etc
Henk van der Heide
User offline. Last seen 7 years 44 weeks ago. Offline
Yes indeed the function of Target update is missing. But maybe this helps a little bit.
If you restore the baseline as a project an open the formal baseline and the current project you wil be able to sort (or organize) on activity ID. What you get is current and baseline activity grouped together so its easier tot compare (the difference)
Shirish Borkar
User offline. Last seen 18 years 32 weeks ago. Offline
As a workaround you can delete and recreate the baseline assuming you have not changed other activity data.
And if that feature is very important to you, you can develop it using Primavera Ingration API.
Alan Chadwick
Cheers Allan,
So the bottom line appears to be that a very important function/feature does not have much flexibility.
Allan Stanners
User offline. Last seen 14 years 21 weeks ago. Offline
This is a known issue in the current version of P3e. I understand it will be rectified in V 5.0 due for release in 1st quarter 2005. This will allow the same functionality that exists in P3 to update the baseline as new tasks are added.
