MS Query and Oracle
Thomas Leahy
User offline. Last seen 9 years 39 weeks ago. Offline
Hello,
In MS Query when I run the following:
Create view tal_contractor_rsrc as
SELECT d.PROJ_ID, d.PROJ_SHORT_NAME, c.TASK_CODE, c.TASK_NAME, c.TASK_TYPE, c.PHYS_COMPLETE_PCT, c.TARGET_DRTN_HR_CNT, c.REMAIN_DRTN_HR_CNT, c.ACT_START_DATE, c.ACT_END_DATE, c.EARLY_START_DATE, c.EARLY_END_DATE, a.RSRC_SHORT_NAME, a.RSRC_NAME, Sum(b.ACT_REG_COST) as T_Act_Reg_Cost, Sum(b.ACT_THIS_PER_COST) as T_Act_This_Per_Cost, Sum(b.REMAIN_COST) as T_Remain_Cost, Sum(b.TARGET_COST) as T_Target_Cost
FROM rsrc a, taskrsrc b, task c, project d
WHERE a.RSRC_ID = b.RSRC_ID AND b.PROJ_ID = c.PROJ_ID AND b.TASK_ID = c.TASK_ID AND c.PROJ_ID = d.PROJ_ID AND ((b.RSRC_ID=3920))
GROUP BY d.PROJ_ID, d.PROJ_SHORT_NAME, c.TASK_CODE, c.TASK_NAME, c.TASK_TYPE, c.PHYS_COMPLETE_PCT, c.TARGET_DRTN_HR_CNT, c.REMAIN_DRTN_HR_CNT, c.ACT_START_DATE, c.ACT_END_DATE, c.EARLY_START_DATE, c.EARLY_END_DATE, a.RSRC_SHORT_NAME, a.RSRC_NAME
I get the error message ORA-00998: must name this expression with a column alias.
For the life of me I cannot see what column it is that is causing the problem.
Tom Leahy
Forum Guest
User offline. Last seen 1 year 12 weeks ago. Offline
Try running this script at the Oracle SQL prompt
SQL > Create view tal_contractor_rsrc as
SELECT etc etc....
you will then get the error message appearing which will point out on which line the error has occured and at which character, alternatively if you have Oracle procedure builder run the query in there and use the built in de bugging editor.
All of the Oracle software can be downloaded for free to be used for evaluation etc.
Also why not post this query to Oracle themselves.
MK TSE
User offline. Last seen 5 years 19 weeks ago. Offline
Some fields must be named. I think the following have problem "...Sum(b.ACT_REG_COST) as T_Act_Reg_Cost, Sum(b.ACT_THIS_PER_COST) as T_Act_This_Per_Cost, Sum(b.REMAIN_COST) as T_Remain_Cost, Sum(b.TARGET_COST) as T_Target_Cost..."
Give a name to these columns.
Field: X: sum(b.ACT_REG_COST)
Table: BLANK
Total: Expression
Criterial: BLANK
If you want to add selection criterial, add one more column with Total is "where" and in hidden mode.
