Problems with Windows Vista Home Premium
7 replies [Last post]
rajesh anand
User offline. Last seen 16 years 11 weeks ago. Offline
Dear Sir,
I am using Windows Vista Home Premium as the Operating system and using Primavera 3.1.When I am typing my password and pressing OK, then I am getting the message a serial number could not be locked. Secondly, I want to know that iscan I Import & Export from Primavera in Windows Vista as the Operating system. Because what happening is when I want to Import / Export in Primavera from excel file, then the Primavera software is automatically being closed. Showing Application error,WOWEXEC caused an access violation in Kernel 32.dll at ox76febo8e. Please revert my queries sir as soon as possible.
Thanks & Regards,
Rajesh
Arnold Puy
User offline. Last seen 10 years 37 weeks ago. Offline
Hi Rajesh,
I’m not quite sure what are the benefits of Service Pack. What I really know is, to fix the debugs of P3 3.1
Try this link:
http://www.planningplanet.com/forum/forum_post.asp?fid=&Cat=2&Top=13620
http://www.planningplanet.com/forum/forum_post.asp?fid=&Cat=2&Top=37132
http://www.planningplanet.com/forum/forum_post.asp?fid=&Cat=2&Top=2383
This might answer to your question.
rajesh anand
Hi Arnold,
Can you tell what are the benefits of Service Pack "P331SrvPk3.exe"?.
rajesh anand
Hi Ronald,
I installed it in C:\P3WIN\" directory only before, it was giving me problems.
Rajesh
Ronald Winter
User offline. Last seen 4 years 31 weeks ago. Offline
Rajesh,
Where did you install P3 on your Vista machine? I am betting that you installed it in the “C:\Program Files\” directory. P3 cannot work properly in this directory because it needs to write to subdirectories were it is install and Vista does not allow anyone to write to this directory other than the System Administrator (this isn’t strictly true, but essentially correct.)
Re-install P3 in the “C:\P3WIN\” directory where it wants to be installed and Vista will not give you any more problems running P3. Good luck!
Arnold Puy
Hi Rajesh,
Did you install Service Pack "P331SrvPk3.exe"? If not, try to install it. You can download here:
http://www.projectstatus.com/pub/
Arnold
rajesh anand
Dear Sir,
I am having still problems,the PRIMAVERA 3.1 application is automatically closes, when i am using filter or import or export, Please help me sir,
rajesh
Arnold Puy
