PROJ Environment Variable is too long
Raja Natarajan
User offline. Last seen 19 years 6 weeks ago. Offline
I get the message ’PROJ environment variable is too long’ and this is preventing me from scheduling my P3 programme. Can anyone suggest a solution ? Thanks in advance.
Raja
Ronald Winter
User offline. Last seen 4 years 31 weeks ago. Offline
Look here for more information. Good luck!
David Moses
User offline. Last seen 12 years 49 weeks ago. Offline
Hi there,
This has been discussed several times before...
This happens when you store your project files in a deep directory (consisting of multiple levels of subdirectories).
Simply save your project files to a directory consisting of only a few levels.
for example => C:\P3WIN\PROJECTS
I hope this helps..
Abhijeet Ranadhir
User offline. Last seen 11 years 31 weeks ago. Offline
The name of the directory folders where you save your file should not be longer then 4 characters. If you have your file in D:/Schedules/projects/cpm.prx it should be D:/Sche/proj/cpm.prx.
