project saved as an image file?
H
Hemanth Kumar 👤 Member for 23 years 8 months
but
Mr Andrew-the web page option i tried before , have you checked the out put;;;Awkward
Andrew Podolny 👤 Member for 21 years 8 months
Another handy option is to "Save as Web Page" under File menu in P3.
Hope it’ll useful.
M
Maria Ahlberg 👤 Member for 22 years 2 months
I have used Acrobat Distiller several years, but with newer versions -P3 has given me trouble. pdf995 is a software that is functioning without any trouble and I recommend it.
B
Ben Walters 👤 Member for 21 years 9 months
I’ve had the best luck with Adobe Acrobat version 5.0. A one page 11x17 pdf comes out to under 30kb usually.
Acrobat version 6.0 was too buggy for me, also too much advertising in 6.0. Always asking me to upgrade or update.
Also, if you’re given a $4000 (US) software, you should also get a $300 software. I started with MS Project, then Suretrak on a $1.2B (US) project. That was fixed soon enough, but I always had Acrobat 5.0.
Dayanidhi Dhandapany 👤 Member for 23 years 4 months
follow these simple steps if you don’t have pdf or anyother xtra fittings in your computer;
from P3 application, File->Preview Picture->save, all pages will be saved as .wmf extension.
All computers will have word application, hence from word application insert->picture->from file, select the .wmf file from the location you saved before.
Raj Maurya 👤 Member for 22 years
If you don’t have acrobat then you can save as picture then insert that picture in power point slide and then print.
V
Vladimir Liberzon 👤 Member for 25 years 5 months
The best way is to print project reports to pdf format. It may be done if you have Acrobat Professional installed.
Vladimir
Featured Partner
Philip Assou-Dodji
jeoffrey reyes
markg
Manjeet Yadav
Pan
Tijo Kurian
Zainab El-Beialy
Kamlesh Parmessur
MR JUDE C ANYAEGBU
GeoVe
