Logic not showing up on plots
F
Forum Guest 👤 Member for 17 years 4 months
M
MK TSE 👤 Member for 24 years 3 months
Also type different driver for that plotter, some driver cannot printer certain line pattern and colour.
J
Jaime Linchangco 👤 Member for 24 years 11 months
I experienced the same problem before and what i did was, at print setup, reduce the resolution of output setting.. say from 1200 dpi to 600 dpi. And it does solved the problem. There, you will see your missing logic now.
B
B Cass 👤 Member for 21 years 9 months
Try sending one page at a time to the plotter.
This sounds like a ’time-out’ problem. Typically, the relationship lines are the last items to be plotted. It looks like either the file has hit its size limit or the communications channel was shut down before the transmission ended. Either way, you are looking at a plot that did not complete to the end. Ah, for the good old days of serial plotting in HP language. It kind of brings a tear to my eyes.
Syed Shoeb
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haque Nawaz
EViLL1
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
