Need Example Shipbuilding Schedule
M
Hi Stormy
When I was aked at an interview what shipbuilding experience I had I said "It is just like a long steel building that floats"
I did not get the job but the principle applies as with a building start at the bottom and work up.
So lay the keel - get the frame in place - fit in the kit between decks - fix the external plating - fit out the interior - order the champagne for the launch.
As I have said many times - if you can’t build it you can’t plan it.
Good luck anyway.
Mike Testro.
Featured Partner
Tijo Kurian
Zainab El-Beialy
Kamlesh Parmessur
MR JUDE C ANYAEGBU
GeoVe
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
