ORA-01017 invalid username/password logon denied
hi everybody,
Could you please help me, I ınstalled primavera oracle database and for configration ı got this problem so cannot use?
thnaks in advance
amir.
P
Primavera SME 👤 Member for 6 years 4 months
If you have a licensed copy currently under support, create a service request at support.oracle.com. One of the engineers can assist.
All ORA errors in P6 are thrown from the database. In this case the database is saying that the username and password you are entering is not valid.
Rashid Iqbal 👤 Member for 16 years 3 months
Amir,
if my memory serves me right; first install the Java and Oracle and then start the installation of P6. If you find in google there are few who have docuemnted step by step installation.
Z
Zoltan Palffy 👤 Member for 17 years
try this
Edit the Existing Configuration
  1. Browse to the P6 Home Directory for the P6 application which is getting the error.
  2. Launch the adminpv.cmd/adminpv.sh or admin.cmd/admin.sh file
  3. Login with the privileged username/password
  4. Expand the configuration being used by the P6 application.
  5. If the configuration appears in red, right-click on the configuration and choose "update to latest version"
  6. Expand Database, Instance Folder.
  7. Update either the Database URL, Username or Password field if they are not correct
  8. Right-Click the Instance Folder, and select 'Test Connection' to confirm a successful database connection.
  9. Save changes and close the Administration Application.
  10. Restart the P6 application for the changes to take effect.
amir küçük 👤 Member for 10 years 7 months
dear sir,
I tried but again failed. Could you please share contact info to send captures ı get. I need help.
regards,
Amir.
dear sir,
Z
try this in the setup
For the Oracle Connection String, type XE
For username, type pubprm$pm
For password, type <this was defined during installation > try admin1
Featured Partner
Sunchana Johnston
Akram Hammam Mohamed
Sagar Raut
Patricio_aoa
Philip Assou-Dodji
jeoffrey reyes
markg
Manjeet Yadav
Pan
