An application events has been intercepted. Please note the reference code for reference. Event code F429B079
Viet Tran
User offline. Last seen 1 year 25 weeks ago. Offline
Hi everyone,
When I update my baseline in Primavera P6, an error occurs as follow "An application events has been intercepted. Please note the reference code for reference. Event code F429B079". So, I can not use update BL function in P6 anymore.
Could you help/instruct me how to solve this problem.
Thanks so much,
Viet Tran,
User offline. Last seen 16 weeks 2 days ago. Offline
glad I could help
Viet Tran
Dear Zoltan Palffy,
Thanks for your consulting. It's now running ok after I re-installed the correct Java version integrated P6.
Thanks and regards,
Viet Tran,
you have the incorrect java version
to resolve this issue, please follow these instructions:
  1. Uninstall the incorrect Java version from the machine it is currentyl conflicing wih p6
  2. Install a Java version that appears in the Tested Configuration list for your P6 version.
  3. Configure the JAVA_HOME environment variable to point to this new java version in the System Environment variables for P6
