Project Calendar not showing in Default calendar Selection Pane
Harry Angell
User offline. Last seen 6 years 10 weeks ago. Offline
I have a project which I created 2 project level calendars for, but even after summarising the project I can't select either calendar to set it as the "Default Project Calendar".
When I go to set the Default calendar it doesnt show any of the project Calendars I have created (I created 2). I have deleted the summarization, and re-summarised but no luck.
Can anyone help?
User offline. Last seen 17 weeks 1 day ago. Offline
When you go to the projects directory make sure that your project is highlighted and you shoudl be able to select the calendar there are the default calendar to use of your project.
Also make sure that you have the admin security rights to do so.
