Progress Calculation
K
Kannan CP 👤 Member for 18 years 1 month
Hi All,
In MS Project is it possible to remove the link between percentage complete and remaining durations.
the concern is that based on the assigned emaining duration the achieved/inserted % progress is changing. MS Project is calculating the progress based on duration only.
Kannan
J
Jose Frade 👤 Member for 21 years 1 month
Another hint:
Change activty type to fixed work.
In field Work put your relative weight for all activities (Depending on project type: M/H, etc)
Input progress of activities in field % Work Progress (Don't use activity % )
Then your duration does not anymore depend on %
Hope it helps
JMFrade
T
Tom Boyle 👤 Member for 19 years 7 months
I think you have understood correctly.  "MS Project is calculating the progress based on duration only."  In MSP,  "% Complete" is always the ratio (Actual Duration)/(Duration), where (Actual Duration) = (Duration - Remaining Duration).  You can't change this.
So if you work for 5 days on a task with Duration=10 days, %Complete = 50%.  But if you work another 2 days before realizing that you have underestimated the time required to do the work by a factor of 2, now you have worked 7 days and have 13 days remaining; your %Complete is therefore 7/20=35%.  Backward progress!
If you are serious about using MSP for earned value reporting, then you should be using Physical %Complete, not %Complete.  Or better yet, measure and report earned value progress using other tools.
Good luck, tom
Featured Partner
xerxes
edwin
jhalluk69
wilmoahyi
Peter Holroyd
Robert Guers
Jerry Robinson
Elyar Safarov
Our Partners
