Printing errors
hello to everyone,
I need some help, this is the situation,why when I do printing for Microsoft program its apper ( THERES IS NOT ENOUGH MEMORY TO COMPLETE THE OPERATION ) even when I restart to my PC then reprint again nothing change i? Can you please  help me ,What I will do to printing such as having a problem, anyway  my activity is 1,700 plus activity. Please kindly email  to [email protected].   Thanks  in advance .
Thanks and Regards,
fescalora
Alexandre Faulx-Briole 👤 Member for 23 years 5 months
Federico,
looks like a bug in your project file; it appears some time when the mpp file is spoiled
do you have the same error with all your files?
if yes, you should reinstall the software from scratch; if no, carefully copy the project data in a new blank file, and cross fingers
Hope it will work and help
Alexandre
M
Matthew Lin 👤 Member for 16 years 2 months
Fescalora,
- go to "project", make sure project start date consistent with real start date; guess that current date there is much earlier than the actual one
- go to "file" then "print", make sure timescale is "all"
- pls double check your page setup via print preview
After that, print should be ok.
If it still doesn't work, pls create a new project then copy & paste the entire project, do the set-up again;
pls be aware of activities with constraints...
Good Luck,
F
FEDERICO ESCALORA 👤 Member for 17 years 7 months
Try to convert it to MS 2003, same problem also with me, my program is MS 2007, but when I convert it to 2003 it works, just try.
Featured Partner
Robert Guers
Jerry Robinson
Elyar Safarov
Christopher Ganotice
Ola Gbotoso
pennyu
jaasland
Doron El
Erim INANC
Our Partners
