Converting to PDF
14 replies [Last post]
Andrew Johnson
User offline. Last seen 1 year 50 weeks ago. Offline
I am having trouble with PDF copies of the MSP programme
I have tried all diferent types of PDF creators.
As soon as I open the created PDF it shuts down Adobe after five or six seconds or if i try to utilise the programme.
I am using MSP 2007 / XP and have tried to solve the problem many ways with no result and was wondering if anyone has had the same problem and has a solution!
Andrew
User offline. Last seen 11 weeks 3 days ago. Offline
Try setting your PDF "Printer" as the "default printer". It works with a similar issue for Primavera Suretrak.
Bertrand GUERARD
User offline. Last seen 5 years 24 weeks ago. Offline
Hello!
I also have this issue with MSP07 and PDFCreator.
We fixed part of the issue by trying to change the ’Print Quality" in the Advanced Options of PDFCreator. It seems to work.
I have another issue with MSP07 when using Group. On the screen it is ok, but when you print (in print preview too) there are colors only for groups names, no more color vertically.
Andrew Johnson
Thank you all for your advice.
I have tried all but I believe Darren is on the money here.
This option has been used on a collegues pc and it seems to work on there and the 3d is turned off. It does seem to work.
Thanks again
Andrew
Darren Kosa
User offline. Last seen 8 years 35 weeks ago. Offline
Hi Andrew,
There’s a known problem when printing to PDF from 2k7. I believe it’s to do with printer tolerances and a 3D Bars option in MS Project.
If you uncheck the ’bars and shapes in gantt view in 3D’ option (Tools > Options > View) then it overcomes this issue.
Not sure if this is the cause of your problem, but it might be worth giving it a shot.
Darren
Andrew Owenson
User offline. Last seen 2 years 25 weeks ago. Offline
Andrew
Apart from the obvious - I have found that the more amended views you have the bigger the file - try to reduce all the views, graphics etc and file save as this sometimes reduces the file size. I would also add that printing to pdf from large file sizes has never been a problem for me (upto 150MB)
Good Luck
Andrew
Colin Blair
User offline. Last seen 48 weeks 22 hours ago. Offline
Hi andrew
When printing to PDF - check in the print properties section - What resolution are you printing at
I usulaly print at 300dpi - the higher the dpi, the bigger the file size
Try reducing the resolution (to an acceptable reading level)
Colin
Andrew Johnson
I have tried all of the below!
With no success I think Rubus might be right and the problem lies with the file size.
What would make a relitively small programme have an abnormal large size file excluding the obvious of inserts and company logo’s?
Andrew
Rubas M. Kutty
User offline. Last seen 11 years 26 weeks ago. Offline
I agree with Colin.
The problem seems to be with the pdf converter. Try converting Word, Powerpoint files to pdf & check if it’s the same case. Also the problem can arise if your file size is too big.
The best might be to reinstall the pdf converter.
Kind regards.
Charleston-Joseph...
User offline. Last seen 4 years 12 weeks ago. Offline
There is a new kid in the block.
pdf911
But, But?? it is costly.
You can only use it in times of emergency.
Happy Planning and Scheduling
Cherie S Blare
User offline. Last seen 16 years 37 weeks ago. Offline
Dear all,
PDF 995 is a free software on the web. I use this for all programme print-outs in PDF.
Cherie.
Colin Blair
Andrew
Check if you can read them on another machine - if so it may be the reader.
The last time I had a problem with the pdf reader, I uninstalled adobe then re-installed it.
Hope this helps
Colin
Andrew Johnson
Thanks Happy Planning
Have tried all types of PDF creaters
It is my thinking that the problem is with the MSP programme.
The problem has arrived after months of having no problem at all. Seems to work ok sometimes and not others
Having no problem with P6 conversions
andrew
Have you tried using primopdf????
I use primopdf and I did not find any problem.
primopdf is a free download in the internet.
