Roll-up Summary in "Group By Summary"
ronaldo celestino
User offline. Last seen 16 years 19 weeks ago. Offline
Hi everybody,
I wanted to show a Roll-up Baseline Summary Bar in "Group By Summary"... I changed the fields in "from" & "to" in bar chart by "baseline start" & "baseline finish" respectively... & I put the Group By Summary in the "show..." field...., but it did not show what i wanted...
Is anybody there encountered same problem I have...
regards,
ronald
Niek Zonneveld
User offline. Last seen 46 weeks 1 day ago. Offline
I’ve had this problem as well. It’s one of the many errors (in the bar styles section) of MSP.
If you replace "baseline start" by "start" it works. In my particular schedule all first activities under each WBS started as planned so I got away with this ’workaround’.
H.T.H.
ronaldo celestino
tnx pals,
i’ll do some experimenting as u adviced james....
i’ll send email for more info jaya...
again thank u for ur time & advice...
regards
J Venkatesh PMP P...
User offline. Last seen 12 years 23 weeks ago. Offline
Groups: GPC Qatar
Ronaldo,
can you explain more...
If u want the project summary, u can get the same by Project summary task from the options menu...
otherwise, if u want to show summary for a set/group of activities, the same can be done adding additionjal information in the Text/number field...
for any details/clarifications contact me at venkat79_j@yahoo.co.in
J
James Griffiths
User offline. Last seen 16 years 41 weeks ago. Offline
Ronaldo,
I can’t get it to do it either. It might be to do with having formatted the grouping AFTER having saved it with a baseline.
It could be worth performing a few experiments.
HTH.
James.
