Rates for Pipeline Welding/ Installation
Emmanuel Udo
User offline. Last seen 6 years 45 weeks ago. Offline
Does any one have, or know where I can obtain, rule of thumb (rates) for pipeline welding/ installation? I would appreciate any such information.
Thank you in advance
Emmanuel
Bernard Ertl
User offline. Last seen 10 years 46 weeks ago. Offline
Emmanual's original query was posted over 3 years ago, but for anyone interested in the same question, eTaskMaker has a dynamic estimating module for piping demolition, fabrication and field installation which considers all the major factors including metallurgy, diameter, thickness, etc.
Mark McElhaney
User offline. Last seen 12 years 45 weeks ago. Offline
Hey Emmanuel, I can suggest you something valuable pertaining to your queries for pipe welding installation. You can PM me if you like. I've studied at a prestigious welding school here in the U.S. You can check if you want to know more about welding.
Samer Zawaydeh
User offline. Last seen 6 years 35 weeks ago. Offline
Dear Emmanuel,
This usually depends on the type of material, thickness, position, environment and other factors.
You can see a lot of discussion in the same forum under the title "Pipe Welding duration"
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=5&Top=58099
With kind regards,
Samer
A D
User offline. Last seen 4 years 50 weeks ago. Offline
Hi Emmy,
You can refer to this great book for planners on pipeline installation
http://www.amazon.com/Estimators-Piping-Man-Hour-Manual-Library/dp/08841...
Estimator’s Piping Man-Hour Manual, Author: John Page
