The contractor exports (using P3e v.5) EPS level Activity Codes as Globals; We import, using P6.2.1, as .XER (code values to be updated) and although the Activity Code is in the dictionary and the assigned values are present (against each activity) the Code cannot be seen in the Group/Sort function. If the code is re-named, it appears. Any ideas?
Global Activity Code does not appear in Group/Sort
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Thanks for your reply Mike. You're right, but in this instance all codes are Global, there are no EPS or Project codes. I've also checked the Import Configuration, which is set to 'update existing' Activity Codes. A poster on the Primavera forum suggested this is a known bug in P6. Have any other P6 users experienced this?
