How to import .PRX file to P6
Salman Ahmed
User offline. Last seen 15 years 19 weeks ago. Offline
Dear all,
please let me know how to import a .prx file to P6.I tried to change the file extension from .prx to .xer but it din’t worked.
Thanks in advance.
User offline. Last seen 14 weeks 2 days ago. Offline
Salman,
In addition from extracting PRX file and converted to P3 file and you are using 64-bit, in order to use the P3 import/export functionality in P6, you must have P3 installed on the same machine where P6 resides. Additionally, you must complete the steps below to register a required DLL file.
1 Open a command prompt.
2 Change your directory to the location of the “ra32.dll” file. By default, the path is C:\Program Files\Common Files\Primavera Common\Ra.
3 Execute the following command: regsvr32 ra32.dll
If you do not want to install P3 on the same machine where P6 is installed or are using a 64-bit operating system, you can instead have your P3 users use a separate P3/XER import/ export utility available from the P6 common files (by default, the location is \Program Files\Common Files\Primavera Common\Convert. Refer to the Oracle Primavera Support Knowledgebase for more information
Ferdinand U.
User offline. Last seen 8 years 7 weeks ago. Offline
