Dictionary 7x.xls ??
7 replies [Last post]
A D
User offline. Last seen 4 years 44 weeks ago. Offline
Does primavera guys have launched supporting excel sheet for P6.7?
Dictionary6x.xls doesn’t work with P6.7
Ronald Winter
User offline. Last seen 4 years 27 weeks ago. Offline
I am not familiar with the internal workings of Dictionary 7x.xls, but I suspect that it uses an MS SQL ADO connection to the database. If that is the case, then your spreadsheet will no longer work once you switch to an Oracle database without re-programming. You will need new references and libraries.
A D
Yes,
I have switched to Oracle database. It still doesn’t work for me. Is there any solution?
Ronald Winter
Raviraj,
When you upgraded to P6v7, did you switch from using the SQL Express database to the Oracle Express database? That could be the reason for the sudden turn of events.
D Artagnan
User offline. Last seen 1 week 2 days ago. Offline
What error message are you getting?
A D
ok, i need to find out then, what the problem is.
It used to work upto last version!!!
D Artagnan
yes it’s still working like a charm in P6.7
Arnold Puy
User offline. Last seen 10 years 32 weeks ago. Offline
Hi Rav,
Dictionary 6x.xls is still working P6 v7.
Arnold
