Printing project calendars in P6
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
xer tool kit is a good utility that can print the calendar as well as do other things please check it out.
i agree to Harold who commented last year. The new 2014 XER Toolkit has improved and produces a good project calendar with each year as a separate work sheet and is free, and can be adjusted for your project start. XER Toolkit can be used as a XER import or direct to your data base.
i agree with Harold in provided a comment. The new XER Toolkit has improved and produces a good project calendar with each year as a seperate work sheet and is free, and can be adjusted for your project start. XER Toolkit can be used as an XER import or direct to your data base.
Hi Janice,
If you’re still looking for a simple solution to print your calendars take a look at this article How to print a Calendar in P6.
Regards.
Hi Janice,
Regards.
The project calender will need not only to show the working and non working days but also the day number from start of the project to the end. Construction management will often require to know how many working days to go and how many have we expended. The wouyld like to know which day is public holiday, religous holiday, perhaps a weather delayed day, non working day due to a national event etc.
This was possible in p3 but not P6. In Asta power project you can get a calendar with the working days shown in red but not day numbers from the start of the project. Some use an excel spreadsheet and manullay build the picture that is required but not the ideal way to proceed.
Try all the software available to select the best to suit your project needs
Tim Readman
Print screen command will be enough..
Janice ,
Did you down load the Comviz software and try it out?
comviz.com.au
Works a treat on many data bases on p6 version 7 to 8.3
Tim Readman
Janice ,
comviz.com.au
Tim Readman
Download XER Toolkit, it is free. It is an addon to Excel. With it you can print P6 Calendars 1 year per excel sheet. It's not as good as P3 but is the best I've found so far
Janice
I needed a project calendar but had to get one made.
Use COMVIZ it works a treat. This is what the scope says it can do...
Comviz Calendar automatically calculates working days depending on the start day. These days do not include non-working days from Oracle Primavera P6 and the days marked as non-working. You can assign different colors and labels for the calendar days in order to create sofisticated calendars.
Tim Readman
Thanks for the replies. Print Screen is what I was doing, but I was hoping there had to be an easier, faster way. Especially when dealing with a several year long project.
Ill try exporting to P3, thats a great idea.
Thanks!
You can export an XER file and open the XER file with Asta PowerProject and print them. You could try exporting to P3 and printing there, or us a screen capture programme such as Snagitand take little pictures of each month and dump into another document.
Paul E Harris
Planning and Scheduling Training Manual & Book Publishers, Consulting and Training
www.eh.com.au
www.primavera.com.au
Janice,
Screen print?
Just a thought.
Walshy
Hi Janice,
This feature is not supported in P6 v6.2.1. and even in P6 v7.
Arnold
