Recover deleted project
Neil Atkinson
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Thanks a Ton Mark
Raviraj,
Get your IT specialists to restore the database from your last back-up to a different location (Create a new Database instance). Map your P6.1 application to connect with that database & then log in & open the project that you deleted. Once you have done this, export out the project as a XER file to your desktop (File, Export, then follow the wizards prompts)
Once you have done this log into your current database and import the project in. This will only work if your backing up your database though.
I had gone to File --> Import, but it doesnt show anything by which I can recover any deleted project. I m using P6.1
Is that limited to P5???
Ravi
It will restore the entire database if you do this, and will revert ALL projects to the last backup status.
You can ask your administrator to restore the last backup of that project.
Naveen
Hi Yusuke Kamui
The only way is to re-import it by using import function , go to file, select import and follow the wizard.
Have a nice day.
