Acitvity Sequence in WBS
S
Suresh Sankarankutty PMP 👤 Member for 19 years 10 months
There is no big deal on this issue.Your question is self explanatory that, you are using Acitivity id as sorting field. So nothing to do but just click on the activity id Titile until you see a watermark of a small arrow pointing down.
Good Luck
Suresh
N
Niek Zonneveld 👤 Member for 21 years 3 months
Minhas,
Patricia is right. P5 uses a FIFO buffer, so the order in which you copy is the order in which you paste.
H.T.H.
P
Patricia Le Clainche 👤 Member for 19 years
Hello Minhas,
Regarding the order you want after copying, on which column do do sort ? By Activity ID? By Start or Finish Date ?
If you want to sort by Activity ID, you should be able, just after copying to change Activity ID in order to sort the good way.
Good luck.
Patricia
K
Karim Mounir 👤 Member for 20 years 2 months
Hi Minhas,
Each activity in a schedule has its unique "Activity ID".
If you want to show the activities in the new WBS sorted as in the old WBS, then u’ve to link the 1st activity in the new WBS with a predecessor in the old WBS (or assign a constarinat date to it) and since the activities in the new WBS are linked then after setting the data date and scheduling the programme the start/finsh dates will be updated, u can sort them by start date (By clicking on the column titled Start).
HTH
Karim
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haque Nawaz
EViLL1
